ORIGINAL: Qema
You know I think I had more success with the hitec eclipse 7 now that i think of it. i will check it out, Can I get a more refined definition on setp 2 above. Step two: Press the set button till the DMD shuts down and goes into program mode.
The manual says one second to press, in reality is it more than one second ?
Actually, it doesn't shut down....bad description. If the speaker or tank is audible, you will hear the engine shut down.
Basically, hold the "SET" buttonuntilthat happens....no need to count the seconds, but yeah...guess it could be a second or right after a second.
<br type="_moz" />
