RCU Forums - View Single Post - help with tamiya dmu
Old 09-11-2010 | 10:53 AM
kclank's Avatar
kclank
Default RE: help with tamiya dmu
Set all the trims and sticks on your eclipse 7 to neutral. Now set the trim for your firing stick to a couple of clicks before maximum down trim. Re-run the setup routine. after the re-run reset the trim on the firing stick to just a couple of clicks below maximum up trim. Now give it a try.
