RCU Forums - View Single Post - Need advice on 500 class setup
Old 09-11-2010 | 09:50 PM
whattheheli
Default RE: Need advice on 500 class setup
I would run a 6s 2600mah pack . The higher voltage will make it pull less amps. I run a trex500esp with stock motor esc. with that size pack. electronics are only warm at the end of pack. I get about 5-6min per pack. with a 15t pinion.
