RCU Forums - View Single Post - Digital Servo Setup
Old 09-12-2010 | 04:10 AM
jetmech05
Default RE: Digital Servo Setup
Hmmm. this is interesting.....How are the servos set up? Are you using 2 seperate channels or a Y? Are you using the same servo horns and control horns on both sides? And finally are the push rods the same length with the same clevises?
The only time I have ever seen a servo meter or matcher used was when 2 or more servos were ganged together to move a control surface.
