ORIGINAL: RAPPTOR
as allways. a new gadget that can fail.. propane is, safer then a flamed up plane,from a wet start.. ''kiss'' is the best way to go.. kero start is a, FAD ,to show off and ,say you have one.. no need for them.. propane works fine .. you got a new ,very pricy gadget,sucks battery life,needs to be replace often.. [X(]
Kero start is not new. It is just new to our micro turbines. There is no simpler method of starting a turbine than using the same fuel and supply that the engine runs on normally. Adding another tank and fuel type is in no way KISS. This is not a FAD so you better get comfortable with it.
I also don't see how this helps Pete737 with his problem at all.
