RCU Forums - View Single Post - ar700 rx dx7 tx help
Old 09-12-2010 | 07:40 PM
417mack
Default ar700 rx dx7 tx help
I have installed an ar700 rx in my Kyosho Spitfire, everything works great untill I start the Saito 56, the thtottel servo will move on it's own up to about 3/4 throttle if I advance to full then back to idle it will idle but then begins to advance again. I have a standard servo on the throttel I would think this would be fine. All the other servos seem fine. The rx is in foam and strapped to the fuse the second antenna is mounted perpindicular to it solid to the bulkhead should I try moving it rapping it in foam or put my old 72 rx back in.
