RCU Forums - View Single Post - engine quits
Thread: engine quits
Old 09-13-2010 | 01:45 PM
jester_s1
Moderator
Default RE: engine quits
To clarify, it's true the air bleed doesn't affect the high end, but the high end does affect the air bleed setting. It has to be set right first before he does anything to the low end. Cutting out upon going to idle from a higher speed does indicate a problem with either the air bleed setting or a bad or wrong glow plug.
