RCU Forums - View Single Post - OUTBOARD MONOHULL
Old 09-13-2010 | 03:50 PM
mickieb49
Default RE: OUTBOARD MONOHULL
Thanks guy's, as i expected, i had seen one outboard on a mono a while ago and as you said it had the cog in the wrong place.
I was trying to correct this by making the hull 860mm long , it seems a little excessive for a brushless outboard but it may also help to reduce the weight i need in the nose, i have also added a flat area near the transom going up nearly 2/3 the length of the hull to create a ride pad.
I am also going to experiment with power trim???/ I know this has also been tried in the past but it all can help.
Just wondering on where it will be best for the COG , 35% , 30% ??????
Cheers
