RCU Forums - View Single Post - Corby Starlet
Old 09-13-2010 | 03:58 PM
  #235
redball8's Avatar
redball8
My Feedback: (128)
Default RE: Corby Starlet
ORIGINAL: CJ-1
HI RB8,
I often thought about putting in a little deatil in that area,at the time the reason was that I wan'ted to keep my model the same as what the purchaser would get in the box, I see no reason why you could not leave out the floor,most of the strength is gained from the formers F2 which is the the former in front of the leading edge,F3 which is the instrument panel and F4 is the former located at the trailing edge of the wing and to top it off the ply doublers on the inside of the fuse should keep it all stable for strength.
I have plenty pic's of the inside of the full size cockpit should you need a little help with some detail.
Good luck and nice chatting.
CHRIS WHITE
Say Chris, I was getting underway with the 38.5% Starlet and was wondering if you could share a few shots of the cockpit? Would like to get "close-to-scale" with a full-body pilot, seat, stick, instrument panel, throttle quadrant, and so on
By the way, did you make it to Muncie this season?
Regards,
- RB8
