Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 DA 50 do not idle down in flight. Help. >
Old 07-03-2004 | 09:53 PM
serge1's Avatar
Default DA 50 do not idle down in flight. Help.
Greetings,
OK here we go. When the plane is on the ground everything is fine: Idle, midrange, top end etc....Evrything works perfect. However when in the air The engine don't idle down. I have to
lower my trim to maximum to land the plane and wait about 30 sec for the engine to idle down.
The tank, clunk and tubing are all fine .
Am I running to lean?? I am confuse.
Any idea?
Serge
Old 07-03-2004 | 10:14 PM
Default RE: DA 50 do not idle down in flight. Help.
To lean on the low needle will cause it not idle down, open it up an 1/16 turn at a time till it burbles midrange then close it back a 1/16, should be perfect. Keep in mind riching the low speed needle also will richen the top end.
Old 07-03-2004 | 10:16 PM
Flyfalcons's Avatar
Yep what mdavies said, too lean on the low end.
Old 07-04-2004 | 12:06 AM
Antique's Avatar
Too lean on the low end will cause it to die when the throttle is opened...[8D]
Old 07-04-2004 | 01:53 AM
Flyfalcons's Avatar
Okay how about "not rich enough"
Old 07-04-2004 | 10:34 AM
wvr's Avatar
wvr
I agree: to lean on the low-needle, try the following, open up the low-needle, the high rpm will be to rich, so you have to close that one a bit. Try this with small adjustments. You will find a point where the engine can idle all day long, and still pick up for full power.
Winfried
Old 07-04-2004 | 10:50 AM
serge1's Avatar
Thanks all for the input. I will richen the low needle and keep you posted.
Thanks again.
Serge
Old 07-06-2004 | 08:42 PM
My Feedback: (30)
Did richening the low needle help this?
Old 07-07-2004 | 10:23 AM
serge1's Avatar
Greetings,
Problem solved. You were right guys....The low neadle was to lean.
The engine is now running fine.
Thanks again
Serge
