 FUEL QUESTION >
FUEL QUESTION
FUEL QUESTION
Old 03-02-2005 | 03:34 PM
causeitflies's Avatar
Default FUEL QUESTION
Can someone tell me the difference between #1 fuel oil and 1-K kerosene?
A local gas station has #1 fuel oil (kero) with a sign that says "Not suitable for unvented home heaters requiring 1-K kerosene". It is also dyed. $1.89/gal.
Maybe some expert can point out the differences between the various kero oils, diesel, etc...
Old 03-02-2005 | 10:31 PM
Default RE: FUEL QUESTION
Is any gas station kerosene 1-K?
Old 03-03-2005 | 03:20 AM
I'm no expert but have a look at the shell data sheet on Kerosene. This may answer your question
http://www.shell.ca/code/products/co...eader/5-16.pdf
HTH
Eric
Jet Rookie
Old 03-03-2005 | 09:40 AM
My Feedback: (8)
There are several gas stations in this area which have kerosene pumps but they all specify K-1 grade on the pump.
Old 03-03-2005 | 11:09 AM
Thanks guys, I'll keep looking. I guess the main difference is sulphur content. Could also cause some acid corrosion I guess.
