Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
 Help me with my 3d plane, 3d screenshots >
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 01-23-2005 | 07:38 PM
Default Help me with my 3d plane, 3d screenshots
Hey,
Here is my .40-60 3d plane design. The Renders are ugly because i did them in autocad. Once i reinstall my 3dsmax ill render it in that.
What do you guys think of the lines? Do you think the wing and tail are correctly sized? I used a naca 16 i think its called and the wing cored is 11 3/8 in and the wing span is 54in. there is 750 sq-in of wing, and 150 of that is aileron.
Thanks, your advise is greatly appreciated
ID:	219696   Click image for larger version
ID:	219697   Click image for larger version
Old 01-23-2005 | 07:39 PM
Default RE: Help me with my 3d plane, 3d screenshots
PS i did it cowelless because its just for me, and i dont wanna bother with that.
Alex
Old 01-23-2005 | 09:11 PM
BMatthews's Avatar
I think your ailerons are too narrow but other than that it looks good. May want to add in some nose blocks or perhaps the big openings are just from the rough rendering?
Old 01-23-2005 | 09:31 PM
yah the nose is left open because it will be easyer to do that once i have the engine in the physical plane...
Btw, those allerons are 3 inches, Should i add more?
And also, what do you thinkg about the naca16 airfoil? is 16% fat enogh>?
ALEX
Old 01-24-2005 | 01:36 AM
BMatthews's Avatar
I'm in the same boat. The sizes of stuff on these 3D models just doesn't make sense but even at 3 inches they look narrow compared to the other stuff you see around. Leave it at 3 at the tips or even cut it back to 2 1/2 but I think you're going to need to go for about 4 inches at the roots to make it look like the other stuff out there.
You may want to post a link to this thread and ask the folks in the 3D or profile forum to drop in here and offer their opinion. They'd know better.
Old 01-24-2005 | 11:10 PM
So is there any math i can do to check the size of the surfaces?
Alex
Old 01-31-2005 | 08:45 PM
go 33% of your cord, and if you can keep the airfoil on your ailerons, foam wing sheeted with balsa are easy to repair, and if you do lightening holes, you can save a lot of weight..... for the fuse, use arrow shafts, if you go to a sports shop, that custom cuts them, you can get left overs, for your empenage and do the fuse with full lenght arrows..... use epoxy with a stuctural filler, so you can join and fillet arrows(stringers) to plywood..... just a thought
