Why not?
NC
Why not?
Alright ive been reading things on this forum for some time now, watching videos and reading various things about this aerial hobby. The thing is, I race cars (real cars not r/c's) and it would be greta for a live in car camera!, Why would i not be able to use one of the aerial cameras? or can i? Someone please help me out here.
Thanks Guys!
Thanks Guys!
NM
RE: Why not?
ORIGINAL: HPIChadder
Thanks Guys!
Thanks Guys!
You would. Think of them as wireless cameras (they aren't just for aerial photography).
Some things to consider:
What frequency to use for the transmitter (and what else is being used on the track).
Line of sight. When you go behind things (other cars, buildings, posts, railing on the track?), the signal may cut out or there may be a interference (so it's not a great picture).
The cameras work well for planes and such since they are up in the air, and there's very little between them and the receiver. But I've put these cameras on R/C cars and driven them around without any problem (just what I've mentioned above, poor signal sometimes)
NM
RE: Why not?
Whats the best camera?
Do you want color, or black and white ( b&w will be more sensitive to low light conditions like at night)
Since this will be in a "full scale" car, you don't really need a tiny camera
And you could get a separate transmitter, so that you could use different cameras
You'll probably want a receiver where you can change the antenna (so that you try different ones).
Start with SuperCircuits (www.scx.com), to get a feel for what's available
My Feedback: (29)
UT
RE: Why not?
Rather than get a small wireless camera get a small HD mini recorder an d then link the video out to a wireless transmitter and you will have a much better picture. Also get a high gain antenna for both the receiver and the transmitter.
Paul
Paul
IL
RE: Why not?
Is live link DURING the race what your after? Or recording the race to view afterwards?
If not, it's easy to just build a home made camera mount and then you've got more $$$$ to invest in a good HD camera.
Just a thought.
Just a thought.
BC, CANADA
RE: Why not?
Yes if you want great quality definitely go with a direct record HD camera, or if wireless maybe go for a Intelligent Flight camera or a KX151 (light and compact) with a 900Mhz A/V TX & RX. Change the antenna on the TX to a rubber ducky one for better transmission. 900Mhz should be more ideal to handle multipathing from things like trees and buildings (to a point), compared to a 2.4Ghz set up. I was suppose to mount a camera and wireless set up on my buddy's Ducati, that would be fun, seeing the front tires spin and the bike carve around corners!!!!
