HIGH SPEED ONBOARD
CA
HIGH SPEED ONBOARD
Hi all,
I am new to onboard video but would GREATLY appreciate some quick inputs.
I want to fly at around 250-275 MPH. If I do onboard video and fly through the "goggles"
1. Do you trust any of the available reasonably priced systems for this purpose (speed)?
2. Would I need to have speed reducing fat antennas sticking off the plane?
3. Which system would you recommend to do this?
3.5. I would stay within Spektrum 2.4 range....so I would need the system to be at least that range.
4. Obviously I don''t want to crash so I need some reliability and a high refresh rate and resolution.
THANKS A LOT GUYS!
Erik
THANKS A LOT GUYS!
Erik
ON, CANADA
RE: HIGH SPEED ONBOARD
I think your asking a lot when your looking at those speeds. Are you new to flying? I would take a look at easystar as a starting point then perhaps multiplex funjet and if you still need more speed... uhh someone else would have to pipe up.
if your running a 2.4ghz spektrum then get a receiver with a secondary antenna... ahhh what else. Get a good video system from range video or one of their competitors... specifically the 900mhz .5w system maybe 1 w. But for weight and range anyways .5 should do. Um... read. A lot.
MN
Ditto a 900MHZ camera system at 1/2 watt I went through future hobbies with a 2.4GHz radio I use a specktrum DX6i should be fine. But the equipment will keep up can you ? [X(]
AL
There are also some very good 5.8 gig video systems out there too. These systems offer better reception and are totally compatible with the 2.4 gig systems. I have found that some of the most compact and durable systems are marketed by the law enforcement suppliers.
MN
Ya future carrys 5.8Ghz systems so that would be an option too[&:]. A little spendy[X(] but you get what you pay for
https://www.futurehobbies.com/items_...id=30&item=182
ON, CANADA
I thought the higher the mhz the less range you get. Atleast that is what I have read. In fact the longest range radio system I have come across runs at 72.something mhz, which supposedly gives a range of 2km versus the 1-1.5km for 2.4ghz etc. Could be wrong haven't read too much on 5.8ghz.
Ivan.
Ivan.
MN
Thats not what I have found @2.4Ghz you have a short wave lenght and can travel farther and through things.
giving the right power. but you get more mutipath. Look at cell phone there @ 1.9Ghz and there clean. and the cops have gone to 2.4GHz for the same reason.
