Inherited a flycamone2 but.....
CT
All it came with was the box, the usb cable, the camera and a piece that plugs into the bottom of the camera. No instructions or disk. I can't get any lights until I plug it in and when I do all I get is WC which per the site stands for wedcam. Anyone know about this camera that could lend me a helping hand?
RE: Inherited a flycamone2 but.....
Patience Grasshopper!!
Your camera may need a new rechargeable battery... www.hobby-lobby.com might have it.
There are about 10 modes and you really need the instruction book to understand it... This is for the flycamone2
You need to have an SD card in the slot... Max 2gig
Three controls On/Off (1) middle is Shutter(2) Farthest button is Mode button(3)
Start by turning on(1) press shutter (2) on the display appears RY for ready
Choose your mode by pressing the mode button (3)
Start and stop the recording by pressing shutter button (2)
Modes
UR - Video Recording (25fps 640x480)
UE - Video Endless (writes over oldest information endlessly)
Ud - Video Dark Environment (darker environment 20fps)
UL - Video Low (same as UR better picture quality dark environ 20 fps - 320x240)
PR - Photo 1280x1024 one photo
PE - Photo Endless interval of 4 seconds until shutter pressed again or SD card full
SP - Spy Video motion detector records as long as thermal sources are moving in the cameras field of view... stops when SD full
SE - Spy Video Endless records over beginning of video
Sd - Save as SR but better picture in dark environment 20 fps
SL - As SR with reduced resolution 320x240 pix
AR - Audio Recording Only
PC - Connected to PC in drive mode will charge the battery
WC connection to PC in webcam mode... download driver at http://www.flycamone.com/driver
180 degree turned recording ... pressing the shutter button a second time afer RY is displayed the recorded image is flipped 180 degrees.
This should get you going...
Check for more on their website.
Modes
ORIGINAL: shanet75
Thanks anyways guys...
OR
Since I updated the FlyCam2 a while a go, that is normal to go to WC. First you have to unplug, turn the camera on, goto PC, plug in, VOILA! You are now in the mode to re-charge or open up the file to see what ya got.
