Go Back  RCU Forums > RC Airplanes > Aerodynamics
Engine offset thrust >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 04-10-2002 | 11:37 PM
Default Engine offset thrust
This is probably a dumb question, but do full scale aircraft use off set thrust to counteract engine torque? If not, why not? If they don't, then why do our models require it to fly properly? Just wondering....................Jerry
Old 04-11-2002 | 12:21 AM
JimCasey's Avatar
Yes, they do.
If you get around a T-28 sometime, this big beast has what looks to be about 6 degrees of downthrust. Side-thrust is harder to eyeball.
Models are "real" planes, and all the rules apply.
