Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Stable low aspect ratio. >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 03-04-2011 | 01:15 PM
Default Stable low aspect ratio.
What would help to control the stability of a low aspect ration flying wing (AR = 0.9)? I have read that they can be so stable that anhedral is needed in some design to allow rudder or aileroncontrol. My targets would be a wing that would self stabilise in wind gusts andgentle bankcontrol anhedral would also be a very good feature for my project.I will be testing using X-Pane simulator before starting the actual model.
Old 03-04-2011 | 02:24 PM
rmh's Avatar
rmh
Default RE: Stable low aspect ratio.
ORIGINAL: ggirf14
What would help to control the stability of a low aspect ration flying wing (AR = 0.9)? I have read that they can be so stable that anhedral is needed in some design to allow rudder or aileron control. My targets would be a wing that would self stabilise in wind gusts and gentle bank control anhedral would also be a very good feature for my project. I will be testing using X-Pane simulator before starting the actual model.
Make a flying pizza add a big rudder and elevons
big or little model it really does not matter - fly the thing and get used to the self stabilizing at low speeds and high angles of attack- THEN- you have a goal to shoot for
Old 03-04-2011 | 03:55 PM
Thanks for the fast good lead RMH. The Flying Pizza is a disk type wing. To refine my question: I'm looking to fly the BOX not the actual Pizza. I mean the beast would be 24inches X 27 inches square flat wing. There would be floats as wing tips (anhedral would also be a very good feature ).
Old 03-04-2011 | 04:02 PM
rmh's Avatar
rmh
The box as you described is VERY stable
Old 03-04-2011 | 05:00 PM
I Found plenty of interesting results looking for Flying pizza boxes. Your lead was excellent. Dial up connection is painfully slow. I'm just back to say thanks. I'll be glad to post testing results from X-Plane.
