Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Gas v. Electric for for long range >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 11-19-2011 | 11:14 AM
Default Gas v. Electric for for long range
I am interested in a list of pros and cons to using gas engines v electric motors with respect to hazards, complexity, and just general ideas about the two. I am looking to build long range planes BTW. Maybe this is better in another forum section, so Moderator, if you feel inclined to move it thats ok.
Old 11-19-2011 | 11:18 AM
perttime's Avatar
Default RE: Gas v. Electric for for long range
Define "long range"
What size aircraft are you talking about?
Old 11-19-2011 | 11:20 AM
range; 100 miles plus, size; under 20 pounds, 9 foot wingspan.
Old 11-19-2011 | 01:08 PM
mboland's Avatar
It will need to be gas.
The weight penalty for battery just makes it impractical for long range stuff.
To get a one hour flying time we needed 2.4Kg of battery with a flight current of only 12 to 15 amps.
Where a small 4 stroke would do the job at 1/3rd throttle sipping fuel lightly.
Old 11-19-2011 | 04:51 PM
charlie111's Avatar
Retriever props.could be lowered ounce in flight to help recharge (Batteries) and a small 4 stroke generaror would use much less fuel than a typical (Helicopter).I think this is an excellant alternative.It needs no tail rotor and is a much more efficiante concept! It has been built and flown on a Full Size version.Cabable of carrying a Pilot.The only differance is My version has wigs similar to a Glider that produce a very large amount of lift at a much slower speed.Also the rigid wing is not subject to oscilation as with thin Rotor Blades! This is the way to build an Electric Rotarywing Aircraft!
Old 11-19-2011 | 06:26 PM
Hi,
I just did a quick search for the RC flight across the Atlantic by Maynard Hill. I got many hits, here is one that briefly explains his set up with a glow converted to gas and a generator on the engine.
http://www.progressiveengineer.com/p...aynardHill.htm
Hope this helps.
Fly4Fun,
Wayne
Old 11-20-2011 | 02:05 PM
eddieC's Avatar
Let's not forget it's been done (100+miles range electric-powered aircraft):
http://www.avinc.com/uas/adc/solar_challenger/
It carried a man, and was back in 1983!  So a model should be possible, but I agree gas has the best power/weight performance.
I routinely get 48-50 minute flights on a Zephyr ARF old-timer with a brushed Speed 600 geared 4:1 turning a 13x8 prop with 10 3000ma NiMh cells.
