Go Back  RCU Forums > RC Airplanes > Aerodynamics
 fuel tank question? >
fuel tank question?
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
fuel tank question?
Old 01-09-2012 | 07:58 PM
Default fuel tank question?
Why doesnt a gas/glow engine deadstick on a down line when tank is nearly empty?
Old 01-09-2012 | 09:10 PM
SeamusG's Avatar
Default RE: fuel tank question?
There is sufficient fuel in the line between the tank's clunk and the carb. The fuel pressure in the tank will remain unchanged as a function of exhaust pressure. An example might help. While on the starting bench, with the throttle wide open, the engine will continue to run for several seconds after I pinch the fuel line closed between the firewall and the high speed needle. The length of tubing between the clunk and where I pinch is longer than between the pinch and the carb.
Hope this makes sense.
Some day when I can call myself an experienced flier I will use good throttle control which means I will throttle back after initiating the down line which, in this case, will reduce the fuel demand and allow the engine to run longer yet.
Old 01-10-2012 | 06:48 AM
What about Gas engines ?  With no back pressure?
Old 01-10-2012 | 07:05 AM
mighty9's Avatar
My Feedback: (10)
Gas engine carbs have a well area that retains fuel. Kinda like a float bowl in a larger 2 stroke engine.
Old 01-10-2012 | 07:32 AM
Why not Bladder tanks ? Like real planes?
Old 01-10-2012 | 07:54 AM
There is a commercial bladder tank, called the Tetra tank, I think.
Lnewqban's Avatar
It does not make any difference if the tank is nearly empty or nearly full.
Check this recent thread out:
http://www.rcuniverse.com/forum/m_10...m.htm#10845494
Old 01-10-2012 | 08:46 AM
Wow . That is a help. Thank you.
Old 01-18-2012 | 10:28 AM
Sport_Pilot's Avatar
It doesn't matter where you pinch the line, there is no vent so the fuel flow stops immediately. That the engine doesn't stop right away means that the fuel mixture is rich and that incoming air is picking up fuel clinging to the crankcase walls and bottom. If it was at peak or lean it will stop immediately no matter how long the line or where you pinch it.
