Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Mythbusters >
Mythbusters
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Mythbusters
Old 02-17-2012 | 09:00 PM
  #76
BMatthews's Avatar
Default RE: Mythbusters
Guys, let's keep the posts on the topic of model aerodynamics. A little light heartedness here and there is fine. But don't make the thread drift into sillyness or it'll get shut down.
As for the conveyor belt thing don't go there. We already had two long running threads in this forum on that topic. We're not turning this thread into a third such bout of craziness.
Old 02-17-2012 | 09:34 PM
  #77
Shoe's Avatar
ORIGINAL: combatpigg
How about model deltas and flying wings need special airfoils with built in reflex to fly at their optimum speed and efficiency...?
I'm pretty sure that for static stability (CG in front of the neutral point), an UNSWEPT flying wing needs to have some effective reflex in order to trim for level flight. Once you go to a delta, or add enough sweep, the connection between stability and need for reflex goes away (there's a reason you don't see many unswept flying wings). I suppose this is one of those myths where something that applies to a special case (usnwept flying wings) gets communicated as a general truth.
