Go Back  RCU Forums > RC Airplanes > Aerodynamics
Sopwith Camel nosing over >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 09-01-2003 | 03:18 PM
Default Sopwith Camel nosing over
I have a Wattage Sopwith Camel. It noses over very well on landing. I also have a GWS Tiger Moth which lands with its tail on the ground. Their wing loading stall speed are almost the same.
I get the felling that the landing gear is too soft. What else make the Camel so good at putting its nose into the dirt?
Any Ideas?
Old 09-01-2003 | 07:54 PM
Ben Lanterman's Avatar
The biggest things are the relationships of the CG of the airplane to the ground and wheel contact. At slow speeds aero forces and moments don't get into it much.
Assume for a moment that the wheels don't turn and that they are directly below the CG. The moment causing the nose over is the weight at the CG times the height above the ground. That moment must accelerate the fuselage moment of inertia about the wheel contact point with the ground.
The forward position of wheel and ground contact point relative to the CG also changes the answer. It adds a anti-noseover moment equal to the weight at the CG times the longitudinal distance between the CG and the wheel contact point. So it tends to counter the moment in the second paragraph.
The wheels free to roll makes the overturning less strong and it also depends on the diameter of the wheels. Big wheels make it less likely to nose over. Free turning wheels make it less likely to nose over.
A larger moment of inertia of the fuselage will make it less prone to nose over. That you can get with longer fuselage.
My GWS is a beauty to land. Its landing gear is relatively short, the fuselage is not too tall, wheels are big (not compared to a big grass blade though) and the tail is long. It is a good example of a bipe that is easy to land, expecially on concrete.
The Camel has a taller landing gear, tall fuselage and and a fairly short fuselage which makes it so much easier to nose over.
How to stop it.
1. Land in short grass and hold in lots of up elevator while the aero forces are still in effect.
2. Get a better pilot. (sorry that just snuck out, couldn't help it)
Does the springness of the landing gear effect the nose over. Only if it stops the wheels from rolling or causes them to toe out to increase their drag on the ground.
Old 09-01-2003 | 10:17 PM
Very good help.
Obviously, the better pilot would help. Unfortunately he is not I.
I was thinking of moving the landing gear (non-scale) forward. Also the landing gear seems to rock back on hitting the grass. So I thought solder another piano wire or epoxy some aluminum sheet to it.
Thank you for the very good answer.
Japan
