CG on a Royal Kit
No matter what model or mfg, the CG is easily found using a yardstick to do some measuring. 9 measurements and you'll have a safe, reliable CG range.
http://www.geistware.com/rcmodeling/cg_super_calc.htm
If nobody shows up with the official number suggested by Royal, you will have an excellent and easy way to get a good answer with that application.
No matter what plane you have, it is easy to locate the CG. All the information you need is on www.rcaeronauts . You can accurately locate the CG and NP for any single- or multi-panel conventional airplane and all of the math is done for you. Calculators typically approximate the CG location for single-panel wings. If you have a multi-panel wing, the accuracy from a calculator, will probably be off.
Caution: It is not the CG location alone, that determines pitch stability, but the location of the CG relative to the neutral point. An accurate way to find both the CG and Neutral Point, is crucial.
Ok Chuck: Not having the calculator program available, I found that Squardron 495 had published their way of finding the CG location.
I am not sure just how large this model is, or its weight, but will give you what I learned from 495. Finished repair, and rebuilding a damaged trainer, I hung the model in a large doorway from the engine cs, vertical stab/ top rudder hinge, and leveled it along the longitudenal axis. Hung a plumb bob from the same hanger above the model, and lowered it until it reached the fuse. Where it pointed
was the CG location. This location proved out correctly as the model was very well balanced during its flying life before my bad landing.
Just finished a 1994 Royal Aire 40T ARF purchased use, and never flown. The instruction manual gave a 4 inch dimension from the leading wing edge for the CG location which mathematically came out at over 38% of MAC. The above method corrected the location to 28% MAC. The plane flys well at this CG location.
Cheers!!!
Rich
Cheers!!!
Rich
ON, CANADA
ORIGINAL: AERORICH73
Cheers!!!
Rich
Cheers!!!
Rich
The method you describe will definitely find where the balance point actually is, but it doesn't tell you anything about where it should be. The idea is that you add ballast (or preferably move heavy things like the battery) to shift the balance point to the recommended position.
Now if you have good reason to think that the manufacturers position is incorrect well no problem balance your model where you see fit.
Most well designed models will balance well enough as built, assuming you don't change things like using a heavier or lighter engine, using a covering that is significantly heavier or lighter than the original etc. but some models will need to have the balance point adjusted to achieve the designers recommendation or indeed to match the pilots requirements.
Please disregard if I have misunderstood your post.
Dave H
Aero rich emailed me to clarify his post, and I have indeed somewhat misunderstood what he was saying.
