Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Who can explain this? Hovering Plane >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 03-08-2013 | 05:59 AM
Lnewqban's Avatar
Default Who can explain this? Hovering Plane
http://www.youtube.com/watch?feature...&v=zys3igBmhB8
Old 03-08-2013 | 09:14 AM
eddieC's Avatar
Default RE: Who can explain this? Hovering Plane
It was an April Fool's prank.
There's a fishing line between both fans, upon which the plane rests.
Old 03-09-2013 | 11:12 AM
I expect that this works for the same reason that a very light ball can hover motionless over a fan blowing vertically upward. According to Bernoulli, a moving mass of air exerts lower pressure. If the ball moves a bit out of the center of the air stream, a higher pressure is exerted on the side of the ball that is toward the outside of the air stream, and a lower pressure on the side of the ball that is closer to the center of the stream. This tends to move the ball back to the air stream's center. However, I don't know for sure if this explains the hovering paper airplane.
Old 03-09-2013 | 04:00 PM
eddieC's Avatar
Re-read post two. It's true. Google it. <div>
</div><div>Tough to refute a prank with a bunch of theories.  </div>
