Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Location of CG >
Location of CG
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Location of CG
Old 04-06-2013 | 03:41 PM
Default Location of CG
Hey guys just had a quick question about the CG of an aircraft.
I was wondering what the manual meant by "190mm—200mm from leading edge at root."
Does that meant the leading edge of the inner most wing rib or somthing different?
Thanks for the help
Old 04-06-2013 | 04:31 PM
Lnewqban's Avatar
Default RE: Location of CG
Measure it aft from the point at which the wing and the side of the fuselage meet.
What ever balance system you use should indicate any point contained by a line that includes that point and that is perpendicular to the center line of the fuselage.
Use empty fuel tanks and gear down.
Old 04-06-2013 | 04:39 PM
<div>Ah I see </div>Thanks for clearing that up for me <span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255);">Lnewqban</span>
Old 04-06-2013 | 04:49 PM
Lnewqban's Avatar
You are welcome
When in doubt, err on the side of nose heaviness, which is always safer.
Old 07-24-2013 | 04:15 PM
Does anyone know where the correct CG is suppose to be on the SkyMaster Hawk [Not the GS one]?
GWtoo
