Wing tube location
Leroy,
Don’t look at it as a scary thing, it is just something that you design to carry desired loads while doing it as light as possible, remember what I stated, make the fittings big and…
I have built a couple of three piece wings in the past with dihedral in the center sections and plug in wings. What I did was built the wing tube sockets in the center section between the spar caps setting the dihedral. Prior to that and on the bench I cut the sockets on the ends to reflect the desired dihedral and CA bonded them together; next I placed carbon tow longitudinally on the top and bottom of the tubes with epoxy resin and continued my layup by wrapping the center section tube area extending outwards from the center about 6” each direction with 3” wide strips of bidirectional carbon fiber wrapped at 45+ and 45- alternating plies, 6 plies in all in the center extending 3” each way and 3 plies going out to the full 6” each way. I then slipped the wing tubes in the sockets, slipped pre cut shrink wrap over the layup areas, heated the shrink tube with a heat gun until the shrink wrap was nice and tight consolidating the layup, I then set all aside until full cure. After that I cut the wrap with a razor blade, remove the shrink wrap, abraded and install as previously stated. This type of center section will carry the loads in your application without allot of weight.
Bob
Bob
Leroy,
Bob
Bob
Leroy
Has anyone in the thread said that?
We look forward to seeing what you've decided to do and how it turns out.
Please be so kind as to show us your progress and tests.
Keep in mind that threads are read by way more people than the ones who contribute to them. It's always good to consider answering not only the question that initiated the thread but the general issues that arise.
So do you happen to have any pictures of the project as it sits?
I will get started on the build as soon as the wing tubes get here and I would be happy to post pictures of what I do to accomplish a successful 3 piece wing, however it has nothing to do with aerodynamics so wonder if it fits here. Plane will be built on the completed build thread of VincentJ,s Sig 1/4 scale Spacewalker 11 build found in KIT BUILDING I'll get the URL and post it here.
Leroy
,s
The fact that a models balance point "moves around" compared to other models is to be expected. Even when 2 different models have identical wings, their CG locations are going to differ unless they also share identical horizontal tails and those are exactly the same moment aft. How many different models have that.
#31
P.S. If you build up a test article as I have described, slide 30" tubes in it, support the ends and load test to destruction, you will see the light.
Bob
#32
Time to move on here don't you think.
#33
spacewFor those that would like to see my wing build watch for it here shortly, www.rcuniverse.com/forum/kit-building-121/11510569-sig-spacewalker-ii1-4scale.html
Leroy
Leroy
#35
My Feedback: (29)
Out of curiosity, Leroy, have you considered a 2 piece wing? I'm going to assume that the original design was set up for a removable one piece wing with all associated mounting provisions. I would think it would be easier to plug the two wing halves together and then bolt the wing as a whole onto the fuse. It would make the build less complicated and you would avoid having to use the wing socket sleeves as a load bearing structure. Just a thought.
#36
I think I'm done here.
Leroy
#37
Leroy
#38
OH
Build it and they will fly....
Three piece wing will have most forces
from the landing impact on the center section..I don't think you need
12" of tube to get that done unless your making the tips very heavy.
If you can pick it up by the wing tips it is overbuilt for flying, but you
can use it as a simple stress test. I would think if your engaging 3 ribs on
each side of the joint that should be enough. Second pin could be just
the first rib to stop rotation. Extra tie into the spare
would be common.
Good Luck!
would be common.
Good Luck!
#39
would be common.
Good Luck!
would be common.
Good Luck!
Leroy
