Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Use Wheel Pants???? >
Use Wheel Pants????
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Use Wheel Pants????
Old 09-25-2003 | 07:41 AM
JWORTNER's Avatar
Default Use Wheel Pants????
What's the common concensus on using wheel pants??? I just got my FuntanaS which comes with wheel pants. Should I use them or leave them off? Pro's and Con's???? I know one con, if you land hard and sheet your gear off, the pants can put holes in the bottom side of your wing.
Old 09-25-2003 | 08:18 AM
Default RE: Use Wheel Pants????
I'm against pants... wheel pants that is... (Notyhing beats a comfy pair of Levis though!! )
Don't get me wrong, they do look good, and really do dress up a model, especially scale..
But:
Another part to build (nothing really wrong with that, really ) but, another part to fiddle with and fit. They never really point the same (one is always slightly higher..) some of them can be a pain when the wheels finally get on. They foul in grass feilds, they always break; never more than 3-5 flights before one is lost! and you need to buy paint just for them... some are better than others, but most (that come with kits) are 2-piece plastic shells that never go together right..
Old 09-25-2003 | 09:06 AM
LouW's Avatar
I basically concur with dr_wogz. The airplane in my avitar is my own design which is dressed up with wheel pants, but I remove them when flying off grass and I made most of the initial flights without them. They do look cool in flight though. I only have two models with wheel pants and my approach is to provide firm attach points and make them easy to remove and install.
I've added a picture.
Old 09-25-2003 | 09:11 AM
David Cutler's Avatar
I've flown a few planes with and without wheel pants, (SIG SE, GP 300 Extra, Graupner Extra) and you can just tell the difference, but I can't really say whether it's better or worse with them. You very quickly get used to the difference and it ceases to be an issue when flying.
-David C.
Old 09-25-2003 | 09:45 AM
It is a question of preference if you are flying a slow plane. They are needed to fair the fixed gear on a fast airplane.
Schmleff
Old 09-25-2003 | 08:51 PM
SST
I use the largest pants and wheels that will still look good, and have had absolutely no problems with mine on a grass field this season. Maybe I'm just lucky...
Old 10-02-2003 | 03:31 PM
I have had good results with the pants on my RV-4 by mounting them both on the landing gear and on the outside end of the axle with a wheel collar type pant mount. This makes them so strong that you can almost think of them as skis in long grass. Sporty
