Loss of Signal - Antenna-less Receiver?
I recently changed my receiver to a Spektrum AR630. I was flying without issue for 2 minutes and then I had a loss of signal. The plane didn't respond and went down into a swampy area. Thankfully, I was able to recover the plane, although, I'll have to figure out how to replace the plastic motor mount in a Durafly T-28 Trojan (the motor mount is built into the foam).
Has anyone noticed a loss of signal? I placed the receiver away from the battery and servos. Any help would be greatly appreciated.
Thank you
Thank you
My Feedback: (29)
I switched to Jeti a little over a year ago, one of their features really opened my eyes to the importance of antenna placement. The Jeti has RX signal reception strength telemetry. I can view reception strength of both antenna’s real time. My last few new airplanes I’ve experienced the reception strength drop below 50% and a quick adjustment of antenna location solved the problem. Not knocking Spektrum, just pointing out that RX location is more critical then we imagine.
tankmates (09-17-2023)
Thank you speedracerntrixie! Being able to check signal strength is a nice thing to have. More transmitters should have that as a standard feature. I'll look at the placement again, although I thought I had placed it away from any interference.
