Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Wind tunnel designers? >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 12-15-2003 | 11:11 PM
Default Wind tunnel designers?
Anybody got any wind tunnel construction experience?
I've been asked for some input on a full scale project, wouldn't mind having someone to bounce idears off of.
Old 12-16-2003 | 12:23 AM
Shoe's Avatar
Default RE: Wind tunnel designers?
There's a text called "Low-Speed Wind Tunnel Testing" by Pope and Rae that may be useful. Some of the information in it is a bit dated, but its a good reference.
Old 12-16-2003 | 08:44 AM
Got it, using it. Thanks.
Old 12-19-2003 | 12:26 PM
MajorTomski's Avatar
Give the folks at Parks College of St Louis U. a call. They designed and built thier own low speed tunnel back in the 60's. It's been moved once and is still in operation. It has a 3'x3' test area.
Old 01-08-2004 | 02:56 AM
Jimmbbo's Avatar
Check out
http://www-tsd.stanford.edu/tsd/pbst...nel/intro.html
http://quest.arc.nasa.gov/aero/event...nd_tunnel.html
NASA also has a number of low speed wind tunnels, and you might go to NASA.gov and do a search there.
HTH
Jim
Old 01-31-2004 | 03:45 AM
I have plans for a small one somewhere I think if you want it email me and remind me please at [email protected] I'll search for it if you still need it- as I have alot on my plate...
