Go Back  RCU Forums > RC Airplanes > Aerodynamics
Biplane CG >
Biplane CG
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Biplane CG
Old 05-26-2002 | 01:39 PM
BillJ's Avatar
My Feedback: (19)
Default Biplane CG
I have this question posted elsewhere......But I have a Bipe whos CG on plans is right at the Back Cabane....almost the trailing edge of the top wing.......Seems a little far back........I have read some articles that seem to lean toward the MEAN Average Cord
of the wings combined to the 25-30% mark......Making this much more close to the front cabane............Any thoughts on a fair place to start and work backward............Plane is a Christian Eagle
Old 05-26-2002 | 02:05 PM
Default CG
I recently purchased a used Dave Patrick Ultimate Bipe, and the instructions weren't provided...
I contacted DP, and they said that the front end of the range is 1" in front of the rear cabane....I think the CG you were given is close, if not right on.
To be safe, you might move it a bit forward, if only to be assured of a stable airplane for the first flights.
Old 05-28-2002 | 01:11 AM
Default Biplane CG
Hi Bill,
Surprised that you did not get more responce to this.
I probably developed the first R/C biplane and from there played for the best with numerous Bipe designs.
Locating the C.G is rather simple but finding the needs to do it
can be a problem.
For example your Christan has sweep back top wing, both?
You umderstand how to locate the MEAN CENTER OF LIFT on a wing? Especially a swept one?
If you do we are in business>
Locate the mean C/L on all 4 panels. The mean points will be out
on the panels. On each wing draw a line connecting the mean points. With the wings mounted mark where these lines intersect
the fuselage side. There will be an upper and lower mark. Connect
these marks with a straight line.
Assuming both wings are identical in size, find the center of the
fuselage line, This is the aircraft wing's C/L, aircraft's C/L will
probably be a bit behind this, thus it is safe to set the desired
balance point in relation to the wings C/L.
Aircraft C/L is known as the neutral point.
Further: often the Bipe's lower wing is smaller than the upper.
For this the same proceedure is followed until dividing the fuselage line is needed.
Associated with this is each wing's area. What percentage is the
smaller wing area of the larger one? Say 2/3?
If so. instead of the C.G, point being half way on the fuselage line i twould be 2/3 UP from the bottom. The larger wing has more
authority thus it's lift is greater and balance must consider that.
Hope I have not made a simple proceedure seem complex, in
practise it really is not.
Good luck!
Old 05-30-2002 | 10:36 PM
pipercub6's Avatar
My Feedback: (16)
Default Bipe CG
Check the July issue of RCM magazine, an article by Art Hood gives a pretty good explanation of what your looking for.
Cliff
