Go Back  RCU Forums > RC Airplanes > Aerodynamics
 ALL WING DESIGN >
ALL WING DESIGN
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
ALL WING DESIGN
Old 05-02-2004 | 06:57 PM
HO-229's Avatar
Default ALL WING DESIGN
Is there a program for designing all wing aircraft that models multiple airfoils in the design with twist & taper?
An example would be using 4 differnt airfoil types[:-]
Old 05-02-2004 | 07:30 PM
BMatthews's Avatar
Default RE: ALL WING DESIGN
Not 4 that I know of but the Panknin twist program allows you to use a different root and tip. www.b2streamlines.com has an Excel spreadsheet for the Panknin formulas that make it painless and the basic forumals if you're a Sadist. I know that only two airfoils may not be scale but it's arguably "good enough" for model sized work.
Old 05-09-2004 | 10:32 PM
b17mik's Avatar
I am not totaly following you an your question but have yoiu looked at compufoil...www.compufoil.com Darn good!!..Michael
