Go Back  RCU Forums > RC Airplanes > Aerodynamics
Work in PROGRESS >
Work in PROGRESS
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Work in PROGRESS
Old 07-19-2002 | 11:13 PM
Default Work in PROGRESS
I have decided to try this Idea
I bought some Off White COVERITE FABRIC VERY tough
I am going to strip off bottom covering of the ailerons
Then replace with the coverite then new color over it !
Should Give lots of torional strenth with out to much weight
If It looks real Good I may do the top
Thanks all RON
Old 07-21-2002 | 11:14 AM
Default NO GOOD USE MONOCOAT !
FABRIC WOULD NOT STRECH TITE ENOUGH... GO WITH MONOCOAT(WHITE) UNDER THE ULTRA IF YOU HAVE THAT STYLE.. OR 1/32 OBECHI WING SKIN THEN ENOUGH YOU DON'T HAVE TO SAND DOWN AILERON S / QUICK /EASY/ STRONG / LIGHT !
ron
