Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Scratch Build Delta Wing CG Problem >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 09-02-2004 | 10:01 PM
Default Scratch Build Delta Wing CG Problem
I recently built a delta wing from scratch and plan on launching it into the air with a few pieces of surgical tubing. My question is; where do I put the cg on this thing. The peek of the airfoil follows the LE and gets smaller as you go to the ends of the wing. I know that the further foreword you put the cg the more stable conditions you have…and the further back you put the cg the less stable it is however it will be more efficient.
Other questions on the same subject are welcome and if anyone wants to know about my little project they can ask about that too!
-Matt
Old 09-02-2004 | 11:13 PM
Default RE: Scratch Build Delta Wing CG Problem
Without any dimensions... root chord, tip chord, span, amount of sweep, a quantitative answer isn't possible.
Old 09-03-2004 | 08:43 PM
jettstarblue's Avatar
More specs please. I've built deltas' with the C.G @ 10%-40% Different configurations require different C.G. placement.
Thickest @ the center , but what about the airfoil shape? Do I understand that the thickest part of the airfoil is the L.E.?
Photos?
You can get away with murder with deltas, but a little more precise explanation will help find your answer.
How much reflex do you have in it?
Old 09-04-2004 | 02:25 AM
For delta wings without reflexed airfoils the CG may be located about 10% ahead of the aerodynamic center AC.
Old 09-04-2004 | 08:11 AM
I'm picking nits here, but that's not a true delta. The info is good however. Need to know more about your delta, Foxtrot. More info please.....
Old 09-05-2004 | 03:53 PM
I'm sorry but i don't have an answer for you. I basically took this foam and sanded it into an airfoil shape. I would also measure it for you all but I am away from my home now and will be for some time. When i get home i can take a few pics and get you all more information but it will not be for quite a while. Check back around Thanksgiving time....
-Thanks
Matt
