Go Back  RCU Forums > RC Airplanes > Aerodynamics
rolling with power >
rolling with power
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
rolling with power
Old 08-04-2002 | 01:15 PM
Default rolling with power
Hi
I apply full throttle from trimed level flight at half throttle and the plane wants to roll left. I have a quadra 35 in the plane. I think I need left thrust?? is this correct and will it stop the left roll with throttle change.
I trim it at full throttle and then when I come down it is out of trim as well
thrust ???
Old 08-04-2002 | 03:24 PM
you need to add right thrust to correct the plane going to the left.
bobi
Old 08-05-2002 | 05:26 AM
Mike James's Avatar
Default In lieu of the dreaded "throttle to rudder" mix...
Yep.
