flaperons or spoilerons for a jet?
ok, i have some experience using flaperons (mixed with elev).... it works well, the only downside being a little mushy controls on landings
i wanted to use this type of setup on my DF jet for obvious reasons (to slow it down on landings) BUT then i read a post about using spoilerons -being much better for landing a jet...... it seems that the jet lands much better in a "nose high" attitude due to the spoilerons (up 10 deg) and they slow the plane down....
can anyone explain to me why decreasing the wing lift would help landing the jet?
if someone uses this type of a setup pls let me know
thanks, Vasek
thanks, Vasek
My Feedback: (12)
Technicaly speaking I don't believe there is anything called a spoileron. A spoiler is a panel usually located on the top of the wing that spoils lift . They are not used to fly slower. They can be used on one side at a time to induce roll or they can be used on both wings at the same time to increase the sink rate or after landing to help slow the a/c. Flaps are used to increase lift and allow one to fly slower. The spoilers themselves were invented to prevent aileron reversal which occured in early jets. The reversal was caused by the aileron making so much drag that the wing twisted creating lift on the wing with the up aileron or aileron reversal.
My recommendation would be to use inboard flaps and outboard ailerons.
Hal, spoileron is the name given to using upwards reflex of the ailerons. Because of the direction travel it's the opposite of flaperons. While flaperons have been used occasionally in full size stuff I believe spoilerons are unique to model aviation and that may explain why you have not seen the term before.
Vasek, the idea is that the use of spoilerons induces a negative camber. It's sort of like flying with a ClarkY or other higher cambered section upside down. To fight the loss of lift of the airfoil section thus created you need to rotate the nose up further. To achieve the lift needed you need a very large angle of attack and that suddenly presents the belly of the fuselage more to the air as well as the wing itself creating more drag due to it's suddenly "dirty" airfoil.
But I feel that this is a technique best used on lighter models. I suspect the landing SPEED may even be a bit higher because of the bad lifting and possible stalling charactaristics. But the ability to slow down should be greatly enhanced so you can set up a very predictable glide slope.
Your best bet would be to post the question about using spoilerons in the Jet forum if you have not done that already. This is one of those questions where the real world experience and parameters counts for more than theory. Find out who is using what and what the model wing loading parameters are. Chances are there's a link between those two, and maybe another factor that will guide you with other's success.
