Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Need rib help >
Need rib help
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Need rib help
Old 08-27-2005 | 12:56 PM
Default Need rib help
Need rib help
I need someone to run a few airfoils for me and export in CAD. I am having problems running an airfoil program as it alters the results too much. Software vendor indicates that occasionally happens. Am needing these to be run by someone in their airfoil program and send me the results. Must be able to view COR files, and early Autocad drawings.
Probably estimating in the range of 10-20 minutes of conversion. If interested, I can send you a Zipped file of everything I have at present. You need to leave a PM with your e:mail address for the attachment.
Wm.
Old 09-02-2005 | 08:22 AM
Default RE: Need rib help
I can help. Send info to [email protected]
Ken Blackwell
Old 09-09-2005 | 01:35 PM
mulligan's Avatar
William, I developed an AutoCAD airfoil routine that reads and plots airfoils (acutally whole wings if you want it) from various airfoil coordinate piont files. Frankly, I haven't heard of "COR" files, but I'd like to take a look and if my program will read it, or if I can tweak it slightly to do so (which isn't much effort), I can whip out ribs of whatever size you'd like. And/or I can give you the ACAD app for your own use.
I'll PM you my e-mail separately.
