Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Hangar ( P-51 >
Hangar ( P-51
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Hangar ( P-51
Old 10-21-2005 | 10:36 AM
Default Hangar ( P-51
Hi
This is my first post on this forum. I have purchased a Hangar 9 Miss America P-51. After joining the wing halves I realized I forgot to check the dihedral. The manual says the wing tip should be 6.25" high My wing ended up at 7.25". Is this additional dihedral going to create a problem wit h the flight characterisitics ? or degrade the performance ?
Thank You
Marcus
Old 10-21-2005 | 11:07 AM
Default RE: Hangar ( P-51
Probably no problem. Any more than that would have. Dihedral causes an aircraft to try and right itself from a bank and too much causes the ailerons to become mushy but adding one more inch should not have much effect. It might look a little funny, however. Sawing the wing in half would be a problem because you'd have to dig out the old spar and that would be messy.
3dbob
Old 10-21-2005 | 11:24 AM
My Feedback: (81)
Yeah, 3D is probably right. I don't think its a problem.
