Effect of changing thrustline
I Have a 61" WS biplane powered by a YS140. I want to do a bit of kit bashing on it and change the cowl to a fiberglass one I already have. To use the new cowl, I will need to move the engine 1/2" higher than the thrustline shown on the plans. No changes are being made to any thrust angles, just a pure offset in the mounting of the engine. What effect will I likely see, or is it minor enough not to have any effect. TIA
John Hayes
[email protected]
John Hayes
[email protected]
There won't be any change to anything.. that's a minor shift in the thrustline.
MOF, any change could only be observable if you made it to a flying airplane. The flight characteristics -might- be influenced, but only by comparing a no-change condition to the changed condition could you find out for sure.
