Basic questions about Tapered wings
PA
RE: Basic questions about Tapered wings
ORIGINAL: B.L.E.
I have heard stories of pilots bailing out of planes that were in a spin only to have the plane recover on it's own and fly in lazy circles until the fuel was gone.
dick you have not made a conclusion as to which type of wing you found to be the best for aerobatic performance without any "nasty surprises" for the pilot. Lets assume that wing and power loading are constant for the moment.
So everyone seems to agree that:
1) if aesthetics were to be of minimal concern, a regular straight wing of any given aspect ratio and some wahout would do the job as well as a swept (tapered) LE wing.
2) if aesthetics are to be considered then a wing which has a tip chord atleast 60% of the root chord, without any washout, is the best.
I am just trying to summarize what all have said so that it makes it easier for me to understand.
model airplane - NO washout - just a simple panel rectangular or with a mild taper / equal swept straight LE makes very little difference
12-10% thick high point -oh 30% - best for strength -then straight to the trailing edge left thick for best strength.
aspect ratio- 3.5---6 . somewhere in there .
All of the figures for man carrying - NON UNLIMITED aerobatic planes - just ar not relevant
a scale wing from a Sukhoi 26 or a Zivco EDGE are good but the airfoil is difficult to get right on the model - SO the scale wing from a Staudacher is about as good as it gets for a really good fully areobatic model.
