New release of Profili!
I send this message to inform you that a new mayor version of Profili, 2.0, has been released.
Here are some of the news:
- Drawing of leading edge, trailing edge, spars etc
- Drawing of the foam cutting template
- One shot drawing of all the ribs of a trapezoidal o relliptical wing
- advanced filtering of the airfoils by thickness, camber etc
- 500 more airfoils added to the database (more then 2,200 now)
- 20 preprocessed polars for every airfoil in the database (20 different Re from 30,000 to 500,000), more then 500 hours of processing for my PC
- automatic process of the polars for new airfoils or Re
- New function to generate a new airfoil as a mix of two, you can also specify the mixing ratio. So you can generate all the airfoil you will find in a wing with different root and tips ones. Then you can verify the aerodynamic of your wing by generating the polars for the new airfoils...
- Airfoil libraries managing
- import export from-to .DAT file
- and more....
Visit the new web site of Profili by
http://utenti.lycos.it/profili2/
where you can have more info and download your version or order a CDRom.
best regards
Stefano
- and more....
best regards
Stefano
