Go Back  RCU Forums > RC Airplanes > Aerodynamics
 How far apart should the wings on a bipe be? >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 03-31-2006 | 07:13 AM
Default How far apart should the wings on a bipe be?
Old 03-31-2006 | 02:55 PM
BMatthews's Avatar
Default RE: How far apart should the wings on a bipe be?
Anywhere from 0.7 of the larger chord to 1.5 the larger chord. The wider the gap the better from an efficiency point of view. Typcial gap is around 1.0 times the chord of the wider wing.
Old 03-31-2006 | 03:00 PM
mesae's Avatar
And they should usually stay the same distance apart during a flight.
Old 04-01-2006 | 09:39 PM
Thanks.
Old 04-02-2006 | 12:08 AM
RaceCity's Avatar
Yes. <giggle>
One should strive for the least flapping of wing possible. (Hate when that happens. It makes a mess)
As was stated earlier, a chord width between the wings is a good starting point.
Old 04-02-2006 | 11:11 PM
Thanks.
I'm planning 48-inch span, 8-inch chord, 1 1/2-inch thickness, fully symmetrical, 7.5-inch from top of bottom wing to bottom of top wing, no stagger. I think a .46 will fly it, but a .61 will have unlimited vertical.
