wing alignment on profile plane
My Feedback: (12)
OH
I recently purchased a cg extreme used. When I got home I noticed the wing alignment looked to be off. When I measured from the nose of the plane to the wing tips the measurements were good. But from the tail to the wing it was off about 3/4 of an inch from one side to another. With this being a fun fly plane and probably wont be flown very fast do you think that it will not fly right? I hate to have to cut the wing loose to realign it,
Jeff
Jeff
Jeff, I assume that it has been flown since it is used so I wouldn't worry too much. If the measurements from the nose to the wing tips are OK then it would seem the wing-fuse is aligned reasonably good. If the measurement from the wing-tail (measured from tip to tip) is a little off then it would indicate that the stab is misaligned in yaw. Check by measuring from a point on the front of the fuselage to the tail tips to check.
I would think that it would be nice to have every thing exact but I would doubt you (or anyone for that matter) could tell the difference due to a small tail misalignment of that type in flight. If the inciidence is OK then you are probably good to go.
If it were a pattern ship that you were fine tuning to the nth degree I would redo it though.
