Conversion from metric to American HELP !!!
FUNCTION: Elevator, Rudder, Motor, Ailerons
CONTENT: fuselage balsa construction and foam with balsa covering, covered with oracover, CNC cut plywood, foam wings with balsa covering, 2 pieces wings with aluminium (dural) wing joiners, foam tail unit with balsa covering, removable stab, landing gear (dural), canopy, fiberglass engine cowl, ABS cowl, hardware, instructions. Stickers
PRICE: 357 €
1850 mm
1700 mm
55.4 dm2
6000g
108.3 g/dm2
E 168
4ch
20-35 cm 2St.
Please convert this and title these I need the wing load. I need oz torque for servos
and flying weight for this plane.
Thanks David
DETAILS PHOTOS:
PRICE: 357 €
1850 mm
1700 mm
55.4 dm2
6000g
108.3 g/dm2
E 168
4ch
20-35 cm 2St.
Thanks David
DETAILS PHOTOS:
RE: Conversion from metric to American HELP !!!
There's a good one at http://joshmadison.net/software/convert/
CA
. . . as has already been said 25.4 mm = 1 inch.
Also, to get a £ sign using an American keyboard key Alt 0163 (that is hold down the Alt key and type 0163) to get £££
etc
-David £C.
etc
-David £C.
1850 mm = 72.8 in
1700 mm = 66.9 in
55.4 dm2 = 859 sq.in.
6000g = 212 oz.
108.3 g/dm2 = 35.4 oz./sq.ft.
20-35 cm 2St. = 1.20 - 2.14 cu.in
/Red B.
1700 mm = 66.9 in
6000g = 212 oz.
/Red B.
Based on the figures shown - be ready for a model which has a relatively high wingloading - I review a lot of models for magazines and to be quite blunt - yours will be relatively heavy ,compared to many current offerings.
If you are an accomplished modeler - you already realize this
If not , expect the model to need some care in setting up best flight parameters.
(what's with all the pop up stuff?)
MB, CANADA
ORIGINAL: David Cutler
etc
etc
... just a thought.
CA
ORIGINAL: fledermaus
But perhaps the price wasn't in pounds Sterling but in Euros, in which case the symbol gbfan used was quite correct...
... just a thought.
etc
etc
... just a thought.
ON, CANADA
