Go Back  RCU Forums > RC Airplanes > Aerodynamics
 From Pusher To Tractor? >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 09-22-2006 | 08:15 AM
Default From Pusher To Tractor?
Hi, I have a 3 blade MAS pusher prop. It's just the right size I need for another airplane that has the engine mounted in a normal tractor configurations (on the front).
Can I just reverse the 3 blade pusher and use it as a tractor prop?
Main difference I see is that the hub thickness near the rear is a little thinner, but since I don't need to bore out the prop, that should not be a problem?
Thanks.
Old 09-22-2006 | 09:01 AM
Default RE: From Pusher To Tractor?
No, will not work unless you can reverse the direction the engine turns.
Old 09-23-2006 | 02:56 AM
Thanks Rodney. Guess I'll have to pick one up from the LHS.
