Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Moving CG forward >
Moving CG forward
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Moving CG forward
Old 01-21-2007 | 11:27 PM
Default Moving CG forward
Hi all,
I'm building a new plane and am almost done, but I'm having a problem. The CG is too far aft. It is built out of Rohacell (really light foam-like substance) so drilling the aft section out won't help much (I've tried). I need about 97 grams in the nose to balance it up, but as that is about 1/7th the weight of the plane I don't really want to add that much (or any) as it will negatively affect the performance.
Does anybody have an idea how to solve this problem?
ATCme[sm=tongue_smile.gif]
Old 01-21-2007 | 11:40 PM
Default RE: Moving CG forward
Add the weight, or move the wing back a bit if you can. Anything else will definitely negatively affect the performance.
Evan.
Old 01-22-2007 | 05:16 AM
You could try filling the rear fuselage with helium!
Old 01-22-2007 | 06:45 AM
I would find an engine 97g heavier or extend the engine out further or move the servos forward if you can
Old 01-22-2007 | 03:54 PM
ORIGINAL: Chrispeace
That's not all that practical an idea.
You have to mount a scale upside down on a ceiling.
Most ceilings are beyond arm's reach.
So you need a modeller height extender to start.
Then you need to have a helium enclosing device added to the scale.
Duct tape or CA might work here.
And then you have to add enough helium to the device to get 97g worth of lift, as shown by the scale..
And then you have to transfer that helium into the aft fuselage.
Quite a chore..
Using a heavier motor is easier.
Old 01-22-2007 | 04:31 PM
BMatthews's Avatar
Modify the nose to make it longer or add the weight.
Old 01-22-2007 | 11:58 PM
97 grams of lead! Easy solution until you get a heavier motor or something like that and just put up with the performance until you do.
