Go Back  RCU Forums > RC Airplanes > Aerodynamics
 CG check. >
CG check.
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
CG check.
Old 03-12-2007 | 02:33 PM
Lomcevak Duck's Avatar
My Feedback: (14)
Default CG check.
Hey guys, help me out here just a second.
I'm building a tailess plane powered by a .15 and I need your help verifying the balance point.
36" span
8" @root
5" @tip
2" sweep @tip
I'm thinking I should balance it at about 20% MAC
using http://www.palosrc.com/instructors/cg.htm
I get the result of:
MAC: 6.62" @ 8.31" from root
Balance point @root chord: 2.25"
When I plot out the CG location it doesn't look right.
I would appreciate if someone better versed in the science of aerodynamics could double check my work please.
Old 03-22-2007 | 02:01 PM
Default RE: CG check.
Build a scale chuck glider!
old git - - - - - aka John L.
Old 03-24-2007 | 01:17 PM
25% back from leading edge at the MAC.
Old 03-24-2007 | 05:14 PM
iron eagel's Avatar
ORIGINAL: Lomcevak Duck
36" span
8" @root
5" @tip
2" sweep @tip
With flying wing (tailess) designs you will find that 20% may be to far aft. One plane I built of the flying wing type actualy needed to be around 12% of mac to be able to glide without trying to pitch up when you cut power (pusher).
Old 03-24-2007 | 07:37 PM
12% is 1.72 inches aft at the root.. a very reasonable place to start.
25% won't work.
Old 04-08-2007 | 11:24 AM
My Feedback: (65)
I can use some help. I'm buliding a 46 size pusher using a Pica Touche kit for the wing and using the kit tail moment. I am having to build a long nose to get the C/G at the proper location on the wing, [Stock C/G on stock Touche plans,] My question is with the long nose [24'' in front of the LE.] Will I have to move the CG forward?
