Go Back  RCU Forums > RC Airplanes > Aerodynamics
Aircraft CG >
Aircraft CG
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Aircraft CG
Old 04-10-2003 | 05:19 AM
Default Aircraft CG
I have a G-202 that when upside down needs a nice amount of down elevator to stay level. So that means the palne is nose heavy, right? So now when i try a do an aggressive loop it will snap out of it. I was under the impression that this condition was a CG that was too far back. Help im confused!
Old 04-10-2003 | 06:35 AM
Default Aircraft CG
You have to combine the c.g location and the elevator travel together. Too far aft and/or too much elevator will result in a snap..
And check your longitudinal dihedral.. tail incidence relative to wing incidence..
Old 04-10-2003 | 11:08 AM
jettstarblue's Avatar
Default Aircraft CG
Todd,
Adjust the C.G to the forward most position on the plans, and the elevator travel to the minimun throws specified. Start moving the C.G back, until it's halfway to the rearmost limit. Add elevator movement until it Snaps out then reduce the throw a little bit.
Jetts
