Go Back  RCU Forums > RC Airplanes > Aerodynamics
Adding airfoil on IFO >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 05-06-2003 | 09:48 PM
stylinsty's Avatar
Default Adding airfoil on IFO
What would adding an airfoil do to an IFO? Would it help with slope gliding?
My lite stick has a cambered wing which gives lots of lift and slow speed.
A stilt near front with a crossway carbon rod going over it would puff up the material nicely near the front and make it slope toward the back.
Would the airfoil help with lift?
Any examples already done?
Old 05-07-2003 | 02:44 PM
Ben Lanterman's Avatar
I experimented with an airfoil shape on my IFO. It is easily done with some small pieces of balsa bent to the right shape. You just shove the plastic covering into the shape you want. I "think" I can make it fly slower. The good thing is that since the mod is cheap and easy and can't hurt then might as well do it and see what happens
I also put airfoil in my Stubenflege slow flier. It looks better that the flat wing and, I think, flies slower.
If you are seeing a trend here it is that I don't really like flat wings. They just don't feel right.
