Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Spinners Explained? >
Spinners Explained?
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Spinners Explained?
Old 06-24-2008 | 12:40 PM
CrateCruncher's Avatar
Default RE: Spinners Explained?
Jim,
I've always thought the spinner manufacturers should make a design that absorbs energy like the crash bumpers on a car. The inside of the cone would have molded-in seams that would split on impact. The volume of the spinner would be filled with styrofoam or some other lightweight, energy absorbing material. Upon impact the spinner would split open sort of like a a lag bolt used to mount shelves on drywall. It might save a crankshaft.
Old 06-24-2008 | 12:45 PM
ORIGINAL: CrateCruncher
Jim,
What a great idea!
Old 07-14-2008 | 10:32 PM
I wish I had Crashes where only the Spinner Broke!
Old 01-07-2009 | 02:37 PM
There is NO rule that a spinner must be used in casual flying!! However, some sanctioned events require spinners, and some events require specific sized spinners.
check this out http://www.modelaircraft.org/files/706.pdf
Old 01-07-2009 | 05:30 PM
There used to be such a rule that a spinner or prop nut was required. I think you will find that the rule no longer exists.
Old 01-09-2009 | 10:01 AM
  #31
From the AMA competition regulations (current) for Aerobatics:
6.5: All planes must have rounded prop spinners or blunt faced hubs such that no propeller shaft protrudes. Rounded devices shall have a radius of point not less than three (3) millimeters.
I think the requirement is only there for specific competitions, not as a general rule.
Old 01-09-2009 | 05:19 PM
  #32
rmh's Avatar
rmh
A little history-
Once upon a time , there were speed control line models which used pointed spinners these were typically 2"in dia and 3 to 4 inches long - nasty things ! Some of the FF guys also used em.
If the plane "got loose" - it would poke a good sized hole in just about anything
the AMA advisory was well intended .
At th present time the rule is "interpreted " as req'd.
Old 05-04-2021 | 07:44 PM
  #33
Originally Posted by Nathan King
In full scale flight, spinners are used to aid in smoothing the airflow around the nose of the aircraft (along with making the aircraft more aesthetically pleasing). As you know, many aircraft features that are necessary for full scale aircraft are not for our models - spinners are one such unnecessary feature in our small models (unless you're a pylon racer). Choose one that looks nice and meets up with the curve of the fuselage properly.
So yeah, spinners are useless.
What about electric starter, will they still work?
Old 05-04-2021 | 09:01 PM
  #34
Hydro Junkie's Avatar
You do realize the last post was over 12 years ago?
To answer your question, Sullivan has a starter insert for bare props:
https://sullivanproducts.com/product/s635/
Old 05-05-2021 | 04:31 AM
  #35
speedracerntrixie's Avatar
My Feedback: (29)
Yea, from a safety viewpoint a spinner is pretty much useless. However there are practical reasons to use a spinner.
1. A well tuned glow 2 stroke is easier to hand start with a spinner.
2. If using an aluminum spinner the slight flywheel affect will aid in a low/reliable idle.
3. Most of the electric only spinners aid in getting cooling airflow directly to the motor.
