Go Back  RCU Forums > RC Airplanes > Aerodynamics
 tail problems >
tail problems
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
tail problems
Old 06-29-2008 | 04:11 AM
Default tail problems
guys, do you think if my horizontal tail fin is about 3-4 degrees crooked in relation to the aircraft nose, wings and verticakl tail fins- would this have a huge impact on the flying performance like the plane going out of control and me not being able to keep it straight in the air? A stalled spin, or every time I puish up the elevator the plane will make a roll towards the ground? Do you think a litttle trim would solve the problem?
Yishht87,
Thanks.
Old 06-29-2008 | 04:47 AM
Ravivos's Avatar
Default RE: tail problems
you really have to define "crooked" better... is it bented ? is it twisted? to which direction? is it only one half or both of them? it the "crookedness" is symetrical ?
Old 06-29-2008 | 05:45 AM
I mean crooked by SLANTED. As in the tail fin is slanted by 2 degrees to the left, at a downslope.
Old 06-29-2008 | 07:04 AM
ok never mind i put up some pieces of wood at the atachment point of the fin and now there is no fault now. Thanks for speaking your bit tho. Bye.[8D]
