Go Back  RCU Forums > RC Airplanes > Aerodynamics
 Won't do Outside loops? >
Aerodynamics Discuss the physics of flight revolving around the aerodynamics and design of aircraft.
Old 07-18-2008 | 03:00 PM
Default Won't do Outside loops?
I have a situation that I've never experienced before in 50 yrs. of RC. I'm flying a great planes Revolver ( odd name for airplane) but anyway it flies extremly well. Nice consecutive rolls right or left, great snaps and spins upright or inverted, excellent knife edge,straight or circle etc., good inside loops but will not do outsides. It rolls out each time I try them. I have tried increasing and decreasing elevator throw. Increasing makes it worse decreasing will hardly even try to loop. It has split elevators so have checked the throw of each side and is equal. Otherwise a good plane, a bit fast on landing so use flaperons.Any thoughts on this?
Old 07-18-2008 | 03:13 PM
Ravivos's Avatar
Default RE: Won't do Outside loops?
It seems your main problem is your CG.
you need a lot of elevator to do an outside but then it snaps (rolls out), and your landings are fast...
move your CG backwards a bit and try it again, do an outside loop without full elevator input.
you will also notice that your landings are a bit slower because you can make the final flair in a higher AoA, with the CG at its place right now you dont have enough authority to flare the plane and make the final approach with the currect attitude.
Old 07-18-2008 | 10:34 PM
BMatthews's Avatar
What if you half roll and then push to an outside from inverted?
Old 07-19-2008 | 11:29 PM
Lnewqban's Avatar
Ted:
I believe you should verify any excessive upthrust of your engine, too big AOA of the wing, or a combination, which forces the model to have the CG located too far forward.
Those conditions may be fighting each other, inclining the balance in favor of one type of loop.
It is possible that your model requires a permanent trim up of the elevator now.
Try the loop with minimum power and radius; at sufficient height, of course.
Also, try what Matthews just suggested above, in addition to start the loop from going up, straight or at an angle.
Another factor to verify is the actual deflection of the elevator under load (stability of the pushroad under compression).
Also consider the centrifugal effect during the loop, as a force resisting the circular movement, which is applied to the CG and is related to the square of the speed of the model.
That centrifugal force will be stronger for loops at high speed and small radius, being able to reach around 7 times the weight of the model (7 Gs).
It seems that your elevator does not have enough authority to overcome the nose up pitch induced by that force.
Right after you apply down elevator, its camber increases and also the lift produced by the horizontal tail, the wing is forced to reduce its AOA and its lift.
As the wing looses lift and the tail gains lift, the combined center of pressure (center of lift) moves toward the tail, initiating a rotation around the CG (nose down torque).
At this point, the angle at which the downwash or wake leaving the wing hits the tail-elevator is also reduced, limiting and reducing the AOA and lifting capacity of the tail.
If elevator up trim was present, the reachable deflection will be less.
As a centrifugal force pushing up appears in the CG, with a value several times higher than the weight pushing down; the nose up torque created by this force overpowers the nose down torque created by the tail, and stops and it may reverse the mentioned rotation around the CG.
The more forward the location of the CG is, the bigger the distance between the center of pressure (lift) and the CG (stability margin); hence, the bigger the nose up torque against the loop.
The opposite happens during an inside loop.
Regards!!
Old 07-20-2008 | 08:59 AM
Lomcevak Duck's Avatar
My Feedback: (14)
Have you tried keeping it on track with your rudder? If it still snaps out, you might get a neat spin [8D]
Old 07-21-2008 | 04:33 PM
If your snap rolling out while doing an outside loop, I agree with the first reply. Your CG is likely too far forward. If your snapping out as you say you are (and adding more elevator makes it worse) you are stalling the wing. You can stall the wing at high speed by increasing the angle of attack beond the limits of the aerodynamics of the wing.
Check your CG and your engine thrust angle and give it another go!! You may also want to check the wing as well as the horizontal stab incidence.
Old 07-21-2008 | 08:01 PM
nmking09's Avatar
My Feedback: (61)
semi-symetrical airfoil on that plane dosen't help
Old 07-23-2008 | 09:30 PM
Want to thank all that offered suggestions to my present situation. Unfortunetly will not be able to attempt any cure at present but will upon getting the oppurtunity.
tedmo
